Broadband speed test
petlew
Is there a speed test that doesn't require Adobe Flash Player?
The Plusnet one does, so does the BTW Performance test that I have on this PC.
Keep on hearing that Flash Player is full of security holes.
9 REPLIES 9
rongtw
Fixes: 12
Re: Broadband speed test
Have you tried the TBB one HTML Thumbs_Up
https://www.thinkbroadband.com/speedtest
TheRoadCrew
Fixes: 9
speedtest.net
Web
or
trc@chromebook:~$ speedtest-cli --simple
Ping: 12.093 ms
Download: 51.66 Mbit/s
Upload: 3.02 Mbit/s
petlew
Thank you.
@TheRoadCrew It certainly works. Noticed it was a beta version. Also noticed the legacy site requires Adobe Flash.
Haven't tried the other two posted yet.
VileReynard
Fixes: 20
Try http://speedof.me/
No Flash or Java & doesn't appeared to be bothered by ad blockers.
Strat
Fixes: 565
....Although when I run it...
I believe it is Kaspersky doing the blocking.
Not complaining about the results though Wink
gleneagles
Aspiring Legend
Fixes: 17
But how accurate
are speed checkers ? Having tried several including those mentioned above my download speed has varied from 22Mb to 32Mb.
We are born into history and history is born into us.
TheRoadCrew
Fixes: 9
Any number of factors can affect recorded download speeds, including:
Time of day
Distance from server
Proximity to router if you're using WiFi.
VileReynard
Fixes: 20
You wouldn't use wifi for a speedtest.
However, any one speedtest should be consistent between tests, even if different speedcheckers vary between themselves.
TheRoadCrew
Fixes: 9
The speedtest result I posted previously was done on WiFi:
Ping: 12.093 ms
Upload: 3.02 Mbit/s
In part because, unless I believe there's a problem with the service, the results are unimportant and in part because the result I get with a device using ethernet
trc@bunsen:~$ speedtest-cli --simple
Ping: 12.283 ms
Download: 52.26 Mbits/s
Upload: 2.97 Mbits/s
isn't neccessarily significantly better.
YMMV
