Broadband speed erratic
- Broadband speed erratic
12-11-2017 5:07 PM
Why? does Win 10 keep on rearranging my desk top icons. And failing to let me place them where I want them?.
This seems to have happened since the last major update.
2 REPLIES 2
Re: Broadband speed erratic
12-11-2017 5:11 PM - edited 12-11-2017 5:14 PM
Right click on the desktop Autoalign selected ?
Edit: For Clarity, View/Auto arrange icons
13-11-2017 1:38 PM
Bait and switch??? I fail to see the relationship between the subject title and the content of the question.
