Broadband 'phone off again!
fotobits
Sadly, after a period of impressive reliability, broadband 'phone is off again this morning.
Hey ho.....
Regards fotobits
11 REPLIES 11
James
Re: Broadband 'phone off again!
We were in the process of upgrading opur Broadband Phone servers this morning and experienced problems and as such, needed to roll back.
Did you see the planned maintenance we posted about the work to Broadband Phone?
Liam
For your refernece, it is here :-
http://usertools.plus.net/status/archive/1185970660.htm
It is unfortunate that it was necessary to roll back - we will be fixing the issues that we came up against this morning and will reattempt as soon as we can!
I do promise you that having a stable Broadband Phone platform is a primary objective of ours and the upgrades we have been carrying out over the last few weeks have seen some real improvements in stability and uptime from where I'm sat.
fotobits
Yes, I did see that warning with regard to the planned maintenance.  However, it didn't come to mind this morning and I was still revelling in the joys of a reliable service, indeed posted a message to this effect yesterday, when boof, off it went!
I was premature, sorry.
I bet you've put back the server that was removed 3-weeks ago!
Fingers crossed for the next go......
paulbrett
Whatever PlusNet have done, it has made it impossible for me to make outgoing calls.
Using X-Lite, a terrible noise is heard while the line is supposed to be ringing.  Does anybody else have this problem? http://paulbrett.plus.com/tmp/Outgoing.wav
I use a Zyxel P2002 for calls normally, and this isn't working at all (probably doesn't like the noise)
Paul.
glloyd
Not working here again either on Grandstream GX2000
Kelly
Fixes: 9
Guys:
Could you check to see if you can use it using xlite for us?
Kelly Dorset
Ex-Broadband Service Manager
bobpullen
Fixes: 316
Same static here with X-Lite. Raising a problem now guys.
Edit: Problem 45343
Another Edit: This should be fixed now. You'll probably need to disconnect and re-register before it's working again though.
puddy
Quote from: Bob
Edit: Problem 45343
works okay with speedTouch 716wlv5
Michael
OshB5
Hi ALL my BB phone has never worked whilst had it pluged in I am using a speed touch and was asked via F9 to try x-lite to the same avail I can make outgoing calls but have never been able to recieve incoming calls at all >:(. They just go straight to the BB Sys ANS phone, its been tested over and over and tested again, they do however say it is their end and should be sorted when they upgrade the servers or somthing. Regs Andy
fotobits
Off again all this week-end and still off!
Usually reconnected on a Monday.
I guess PlusNet don't use this service!
bobpullen
Fixes: 316
Working fine here despite an hour or so earlier on today. You still having problems?
