Broadband Phone
AndrewB
Broadband Phone
Problem receiving calls. My X-Lite works fine on outgoing calls but if someone calls me it rings on my computer and I anwer but their telephone just keeps ringing until the answerphone picks up the call . It was suggested that my router was the problem so I opened all the ports required , set up a static IP address and made sure my firewall wasn't blocking anything all to no avail . Has anybody out there sorted this problem and if so how?
Please help.
1 REPLY
Fixes: 10
Re: Broadband Phone
Which version of X-lite are you using? If it's the latest (X-lite 3) I suggest you have a read of the topics about about X-lite in the VOIP Trial forum.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
