Broadband Phone Performance
- Broadband Phone Performance
- « Previous
- 1
- 2
- Next »
Re: Broadband Phone Performance
18-10-2007 9:42 PM
As we keep hinting, we think we've hit on a very good answer to our Voip woes. It's not coming as quickly as we would like, but it is coming and as soon as the eyes are dotted and the teas are crossed we will share the plan.
I for one am quite excited about our approach to this now - I'm just sorry that we are making people throw phone handsets about in the mean time.
Ian
19-10-2007 8:12 AM
Will this new plan your talking about actually help me to login to the BB phone service? i'm getting error 479 We don't accept priv - that's all i can see and i do not know of a way to expand the x-lite software to see more of the message, is there a way?
i've done everything to the letter. To be honest it is a service addition and therefore can be excused for the odd hickup, afterall this is human invented technology - it's not going to be perfect by a long shot
But just occasional use would be nice.
Pete
19-10-2007 10:09 AM
....and thanks for your response Ian W. I refuse to allow even the smallest amount of enthusiasm, certainly not excitement, however, I continue to live in hope!
Regards....
19-10-2007 11:39 AM
19-10-2007 1:00 PM
Quote that's all i can see and i do not know of a way to expand the x-lite software to see more of the message, is there a way?
Do you have the error logging enabled?
If not then with X-Lite open right click in the phone display window and select ‘Options’
In the options window look at the bottom left and you will see a button [Advanced], click this to slide up the menu underneath.
Click the ‘Diagnostics’ icon and from this page you can turn on the logging features.
I used this to find an error problem I was having, it just turned out I had changed my password and forgot to tell X-Lite.
Hope this will help, regards, P.
19-10-2007 3:45 PM
For periods it has worked well, best early this year. Since then my only change has been changing from Anytime to BBYW-2 with an accompanying drop in download speed of about 1,000kbps, however, I don't think that'll be a contributer.
Regards and thanks.....
20-10-2007 9:28 AM
outgoing calls have all worked fine (so far).
20-10-2007 10:54 AM
Regards....
21-10-2007 7:04 PM
Ian
21-10-2007 8:52 PM
21-10-2007 9:14 PM
You're using a connection through your PC with X-Lite s/w aren't you?
Regards
21-10-2007 10:42 PM
yes i am using x-lite.
it stopped when i changed router - it was the NAT firewall that was causing the problem and i couldn't take it down on the belkin i had
22-10-2007 10:28 AM
Anyone any clues as to what might be the problem ?
25-10-2007 8:01 AM
- « Previous
- 1
- 2
- Next »
