Broadband Phone Issue
pcoventry76
Am i the only one to get this? , i hope not so it can be looked at
I just used it to test my home landline, after 7 mins i went to cut it off but it would not. when it got to 8 minutes i shut the software down, still going, disabled LAN , still going, turned off my router, and all LAN connectors, still going
rebooted PC, still going
My landline was in the incoming call state for a further 18 so so minutes, my landline was silent and when i rang it it said i was on the phone ( and i got 1571)
I'm not bothered about the minutes i've lost as i'll never use them all anyway
1 REPLY
Fixes: 81
Re: Broadband Phone Issue
Sounds like the issues we were having prior to the recent maintenance work. Are you using X-Lite? I've often found I have problems with the X-Lite software that I don't see with other clients/hardware.
I have seen what your describing before but it shouldn't be occurring all the time. I believe it happens when the Asterisk servers are keeping the connection alive.
BTW, I'd welcome this sort of feedback in the thread here following the recent Service Status.
