British Summer Time
john1827
British Summer Time
This morning UK moved to British Summer Time
My Plusnet Hub One has not - Why?
11 REPLIES 11
Legend
Fixes: 248
Re: British Summer Time
@john1827 Welcome to the forums. Where are you looking for this time? Sorry, but I don't know the Hub1, so please explan clearly - a picture would be even better.
john1827
Hi jab1
We have been with Plusnet just over a year
Noticed the Plusnet Hub did not change to British Summer Time last year which meant I had so set the Internet Access Control times back one hour so they would operated when required. Also the  Event Log timings were out by one hour. I just put up with it then.
Just noted there have been previous posts on this topic last year:
Plusnet Hub System Time Wrong in British Summer Ti... - Plusnet Community
Wondered whether there had been a fix and an update to the Hub 1 firmware that I have not received
Legend
Fixes: 248
@john1827 Looking at the linked post in yours - I can't see if it has been fixed. The only idea I have at the moment is to tag @bobpullen (the network expert on PN staff), and see if he picks this up.
Sorry I can't be of more help, but maybe Bob will now respond when he's back on line.
john1827
Ok, thanks for your time. I'll wait and see
Legend
Fixes: 248
Just another thought - which firmware are you on?
bobpullen
Fixes: 315
This has been fixed, however the firmware has not yet been deployed. Plan was to have released it by now, but there have been a few last minute issues that we're still working through.
@john1827 - If you reboot your hub, you should find the time is reflected accurately. Let me know if not.
john1827
Thanks Bob and jab1
Following reboot System up, firmware version: 4.7.5.1.83.8.289 (was 263)
Problem solved
Bootneck63
I have the same issue but even after re-boot the router is only using GMT. Software details - Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 26/03/19. Any ideas?
Legend
Fixes: 248
@bobpullen - can you sort this?
bobpullen
Fixes: 315
@Bootneck63 - try another restart.
Bootneck63
Worked a treat, thanks @bobpullen
