British Summer Time
FIXED- Subscribe to RSS Feed
- British Summer Time
28-03-2021 8:19 PM
Re: British Summer Time
28-03-2021 8:35 PM
@john1827 Welcome to the forums. Where are you looking for this time? Sorry, but I don't know the Hub1, so please explan clearly - a picture would be even better.
28-03-2021 9:34 PM
Hi jab1
We have been with Plusnet just over a year
Noticed the Plusnet Hub did not change to British Summer Time last year which meant I had so set the Internet Access Control times back one hour so they would operated when required. Also the Event Log timings were out by one hour. I just put up with it then.
Just noted there have been previous posts on this topic last year:
Plusnet Hub System Time Wrong in British Summer Ti... - Plusnet Community
Wondered whether there had been a fix and an update to the Hub 1 firmware that I have not received
28-03-2021 9:43 PM
@john1827 Looking at the linked post in yours - I can't see if it has been fixed. The only idea I have at the moment is to tag @bobpullen (the network expert on PN staff), and see if he picks this up.
Sorry I can't be of more help, but maybe Bob will now respond when he's back on line.
28-03-2021 9:54 PM
Ok, thanks for your time. I'll wait and see
28-03-2021 9:59 PM
Just another thought - which firmware are you on?
28-03-2021 11:17 PM
This has been fixed, however the firmware has not yet been deployed. Plan was to have released it by now, but there have been a few last minute issues that we're still working through.
@john1827 - If you reboot your hub, you should find the time is reflected accurately. Let me know if not.
29-03-2021 7:55 AM
Thanks Bob and jab1
Following reboot System up, firmware version: 4.7.5.1.83.8.289 (was 263)
Problem solved
19-04-2021 5:25 PM
I have the same issue but even after re-boot the router is only using GMT. Software details - Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 26/03/19. Any ideas?
19-04-2021 5:38 PM
@bobpullen - can you sort this?
19-04-2021 5:51 PM
@Bootneck63 - try another restart.
19-04-2021 5:56 PM
Worked a treat, thanks @bobpullen
