Bresser WSX3001 7 in 1 sensor weather station with WiFi
tonykirkhan77
The console receives all the data via a wireless link, all working correctly.
A WiFi connection is required feed apps.weatherunderground & WeatherCloud,on my PC. ASUS chromebox 4 chrome OS latest update.
Problem,  Plusnet FP3C - Add connection SSID PWS-E32210 returns :- Failed to connect to network PWS-E32210 Out of range.
Have changed channel 1 (very crowded) to 12 empty.
Hope someone knows the answer thanks for reading.
1 REPLY 1
Fixes: 558
Re: Bresser WSX3001 7 in 1 sensor weather station with WiFi
Some devices can't use channels 12 & 13.
