I have a Brennan B2 (CD Storage & Internet Radio) fed from a Plusnet Router, sage I think.
By putting the Brennan B2 IP address in the computer I can view and edit my record collection. This works now.
I also had the IP in my Android smartphone it used to work. Now after a couple of seconds it states timed out. Looking in the search engine it said re-set the router I tried that it did not work.
Is there anything else I can try?
kind regards,
Roger
