Boosting WiFI upstairs
- Boosting WiFI upstairs
28-11-2019 8:58 PM
I'm looking for a suggestion to boost my WiFi for Upstairs in my house does anyone have any recommendations, please?
Re: Boosting WiFI upstairs
29-11-2019 10:38 AM
1. Get a WiFi repeater. For: cheap. Against: It’s the luck of the draw if you can find a suitable location to install it.
2. Run an Ethernet cable upstairs and fix a Wireless Access Point on the end. For: will definitely work, fairly cheap. Against: having to run the cable through your house.
3. Use Powerline devices with a wireless remote unit. For: ease of installation. Against: depending on your household wiring might not work very well, see https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
4. Mesh wireless units. For: with sufficient disks you can ensure whole house wireless coverage. Against: cost.
Everyone has their favourite, which they will promote. Only you can decide what’s right for you so I recommend that you do your own research.
