Bookmarks
- Bookmarks
Bookmarks
09-04-2017 8:38 AM
I wish to copy my extensive bookmarks list from one FireFox to FireFox on another computer. But not lose the list on the first computer.
One method I've looked at suggests the "donor" FireFox will lose its bookmarks, is this so?
That one computer is Win7 (the donor) the other Win 10 I hope shouldn't make any difference...hopefully.
Re: Bookmarks
09-04-2017 9:00 AM - edited 09-04-2017 9:03 AM
Using FF on Apple Mac OSX (Should be same for Windows)
Menu... Show all bookmarks...
Then two options, rhs drop down menu
Backup all sub directories.
Does not destroy nor remove current Bookmarks
Then restore / import on second computer
I also save to a backups directory
(I use this all the time to backup my bookmarks)
If not exactly the same, Windows must have some equivalent menus
Re: Bookmarks
09-04-2017 9:02 AM
Easy-peasy... use "X-marks" ... you should be able to google that, I think it is a firefox addon... I use it across three computers... and it updates instantly...
When you boot up the second computer, it should automatically update to what you had on the previous computer.. so, if yesterday, you bookmarked 6 new pages... and today you went to scotland, with your netbook, and booted up.. your bookmarks would be the same as yesterdays machine..
this link may work for you...
https://addons.mozilla.org/en-GB/firefox/search/?q=xmarks&appver=52.0&platform=windows
Re: Bookmarks
09-04-2017 9:26 AM
even easier , lust log into Firefox sync it saves your bookmarks so any PC , tablet or phone every time you log it it shows all your bookmarks . No add on,s so simple
https://support.mozilla.org/t5/Sync-and-Save/How-do-I-set-up-Sync-on-my-computer/ta-p/21417
Re: Bookmarks
09-04-2017 10:47 AM
Procedure to backup bookmarks to an HTML file which can then be restored to a browser on another computer or a different browser on the same computer.
Re: Bookmarks
09-04-2017 10:54 AM
With respect to "backing up bookmarks" procedures....
doesn`t this mean that every time you close the computer you have to back up manually, to ensure the days "takings" have been "banked".. ? ? ?
then you have to remember to take a copy of that "back up" file, and install it on the secon/subsequent computers ? ?
a bit of an archaic system, when Xmarks or Firefox synch does it automatically, and it is available updated no matter how soon you "boot up" the second computer.
Re: Bookmarks
09-04-2017 10:59 AM
totally agree @shutter Firefox sync , updates every reboot automatically .
so i get all updated bookmarks on my phone or tablet wherever i am
Re: Bookmarks
09-04-2017 11:05 AM
@rongtw Does FF update automatically, during use... i.e. if you boot up your second computer, do you need to activate the update on the second computer? or are the "new" bookmarks immediately available, and does it mean the updated version (of the newer bookmark list ).. is not available to the second computer, until a reboot on the first computer ?
Re: Bookmarks
09-04-2017 12:53 PM - edited 09-04-2017 12:56 PM
@shutter in use if i add a Bookmark on PC it updates on my phone
dont think its instantly but it must update regularly
Re: Bookmarks
09-04-2017 1:29 PM
You can also force a resync of the bookmarks on both machines by clicking the 'sync' icon on the Firefox options menu.
Re: Bookmarks
09-04-2017 2:23 PM
@rongtw& @NorthPole OK... Thanks for that info...
Re: Bookmarks
09-04-2017 2:37 PM
The OP asks for a means of transferring bookmarks from one machine to another. Nothing about keeping them in step thereafter. For a one-off transfer the html method is OK and provides an archive should the need to revert arise.
Also the HTML means of transfer could enable transferring to a different browser if desired.
Other methods have the advantages already mentioned. It just depends on what one is trying to achieve.
Re: Bookmarks
09-04-2017 3:36 PM
Time Machine(s) on my iMacs automatically back up everything, including Bookmarks from all my browsers, every hour !!
The backup happens on each Time Machine (3 per iMac) automatically in rotation.
And with USB3 & Thunderbolt connections it's very fast.
Re: Bookmarks
09-04-2017 4:27 PM
@alanf Point noted... however,... there seems little point, or advantage of having bookmarks that are not "up to date".. and would you want to transfer your "old bookmarks" from an old computer to a newer one, even if it were only a week or so, ..... or from a currently used one to a second one, that did not include your latest finds ?
A bit like keeping old bus or train timetables... just in case they come in handy ... ( not for the historical/monetry value on flog it ! ! )...
Whilst many of my own bookmarks, I have never referred to, over the years... I would want an "up to date" list to be available on both computers, and I am sure the OP would too... !
Re: Bookmarks
10-04-2017 10:47 AM
Actually I'm not that concerned about both machines having the same up to date bookmarks, I don't add to them that often.
The older machine (Win 7, upgraded several times from the pre-installed Win 98) is showing signs of getting past its sell by date, the newer machine (Win 10 from new) is not used much at this time other than getting it to the same(ish) content spec as the old one so hopefully when the old one finally expires the change over can be as seamless as practicable, this includes the FireFox bookmarks. I very much recall when the hard drive in an even older machine failed I lost a number of cherished bookmarks, that took an age to relocate. I just don't want to have to go through that again.
Otherwise most of the content of the old machine is backed up to an external hard drive that works with both machines, but so far (until now) I hadn't quite worked out the bookmarks.
My thanks to all those who responded. And pointing out it is an easy fix.
