Bookmarks Tool bar on Firefox/google search
Fixes: 19
Does anyone know if it is possible to remove the Bookmarks Toolbar on Firefox/Google search page?
If so, please elucidate, how to get rid....
pierre_pierre
Re: Bookmarks Tool bar on Firefox/google search
right click on it on the top File - Edit View bar and remove the tick
Steve
Seasoned Pro
Hey that's pretty neat, Got almost an extra half inch on my screen now. Smiley
If life gives you lemons, make lemonade.
Fixes: 19
Thanks Pierre, .... been annoying me for a long time....... as SteveM says.... got more screen for ME, now ! ! .. Wink
pierre_pierre
and next time I do a silly Guessing thing, dont be sanguine and answer correctly straight away, no wonder there isnt any one on Chit Chat
Fixes: 19
There was a time window of 2 hours and 24 minutes before I posted my response..... I did so, as nobody else  1... knew the answer...... 2..... seemed to be interested enough to have a guess....
and it`s not MY fault that chit chat is so quiet..... so don`t blame me....... Wink
Fixes: 62
3. Knew the answer was correct so didn't want to steal Pierre's thunder  Grin Grin
pierre_pierre
much more interesting than crop circles as well
Bookmarks tool bar is quite good. I use it for my most used RSS feeds. I am using Chrome on my work laptop and it doesn't have the same feature and I really miss it.
Well, my Firefox bookmarks toolbar has a little "x" top right to switch it off if required. To get it back: "View/Toolbars"
Personally I prefer it there all the time, but I'm funny that way....
palexgood
Quote from: Petlew
One of the reasons I use Firefox is the All-in-One Sidebar add on.  Once installed you never see your sidebar until you move the mouse pointer very close to the left or right edge of the screen.  Its very sophisticated with an excellent choice of options. You can switch it to show not only bookmarks but history, downloads and add ons.  I was so impressed with it that I even donated £10!  When Chrome was being developed I tried to suggest they include a similar feature but, unfortunately they didn't bother.  I've tried to find a similar add on for Chrome without success.  This is the link to the Firefox All in One add on.  https://addons.mozilla.org/en-US/firefox/addon/1027/
