Boo Hoo! can`t get rid of Yahoo!
- Re: Boo Hoo! can`t get rid of Yahoo!
27-06-2008 11:00 AM
O.K. this is really simple..... Or so I thought...
I have managed to get a Yahoo toolbar on my browser (firefox) which I do not want.... I have just renewed my copy of CCleaner, and it has appeared.....
I don`t want it.... I have been to settings>Control Panel and Remove programs. It has been removed from the list, but still appears on my browser.... I have shut down and re-started the laptop.... still there. It does not appear with IE7.
I looked for an "uninstall" for Firefox on the control panel, but can`t see it listed, so cannot remove firefox either.... (with intention of re-installing it) (presumably if I just re-install, it will continue with the Yahoo as a standard part...)
Any offers? ideas?
Any offers? ideas?
3 REPLIES 3
27-06-2008 11:12 AM
Are you referring to the AVG Security toolbar that uses Yahoo!, which gets installed on your default browser as part of AVG 8.0 installation? If so, you may have 2 options.
1. Uninstall AVG 8.0 and re-install without the toolbar add-on.
2. Uncheck the toolbar in Firefox (I have no experience of Firefox so I can't advise on how to do this, but in IE7 you can uncheck the toolbar under the View>Toolbars menu.
If this works, it will probably be the first time that I have helped anyone on these forums, starting to payback for all the help and advice I have received.
My other car isn't a Ferrari
27-06-2008 11:29 AM
Hey! Maranello !..... Go to the top of the class ! pity the * are not big enough but you get 5 of them *****
The view > toolbars > uncheck Yahoo did the trick....
See! I new it was easy! just could not remember how to do it the easy way , so had to do it the hard way first !
ps No, it wasn`t the AVG 8.0 version, cos I saw the box that needed unchecking when I installed it.!
27-06-2008 11:40 AM
Glad to be able to help.
Sometimes it takes a simpleton to come up with a simple solution to a problem.
