Bluetooth
Fixes: 9
Bluetooth
What sort of range could you expect from a bluetooth device ?
My wife's laptop with bluetooth built in only works about 6 feet from the printer, I Have tried an external usb bluetooth dongle (or what ever it's  called) on my desktop machine which is about 25 feet away and that is not recognised either
Fixes: 4
Re: Bluetooth
You need to check what "class" each Bluetooth device is from the product specification.
    * Class 3 radios – have a range of up to 1 meter or 3 feet
    * Class 2 radios – most commonly found in mobile devices – have a range of 10 meters or 33 feet
    * Class 1 radios – used primarily in industrial use cases – have a range of 100 meters or 300 feet
from http://www.bluetooth.com/Pages/Basics.aspx
jojopillo
Re: Bluetooth
Hi gleneagles,
A quick google on the subject seems to suggest that even the most basic devices should operate between 5-10 metres away.
Jojo Smiley
Fixes: 4
Re: Bluetooth
Another consideration, is whether you are in an area with more than three WiFi channels being used, as WiFi and Bluetooth use the SAME FREQUENCIES so there is a possibility that Bluetooth connectivity and WiFi throughput can be impaired if most of the WiFi channels are already being used.
Crazy
CX
Re: Bluetooth
Quote from: purleigh
Crazy
And wireless keyboards and mice, which these days are moving to vendor-specific 'standards', again in the 2.4GHz band, even though the older 27MHz devices worked just fine at realistic computer-to-mouse distances.
Fixes: 9
Re: Bluetooth
Thanks for the replies, I Purchased a Belkin Bluetooth adapter from Amazon for £7.99 (free postage) and it works perfectly.
