Bluetooth query
gleneagles
Aspiring Legend
Fixes: 17
Bluetooth query
I have a samsung tablet that has bluetooth enabled. I also have 2 speakers both bluetooth enabled but different makes.
soundbar is LG and speaker small anker.
The tablet can pair with both speakers but what it cannot do is play music from both speakers at the same time.
What is the easiest and cheapest way to get around this problem, assuming it can be done.
I have looked at bluetooth recievers/transmitters but the advice varies, some say that would work but others say no.
Any advice would be appreaciated.
We are born into history and history is born into us.
3 REPLIES 3
Mustrum
Fixes: 76
Re: Bluetooth query
I suspect its a bit like a phone, you can connect to many Bluetooth devices, just not at the same time.
No doubt Google would explain more the technicalities, but I believe you will need a device and controller that allows multiple connections - Sonos seems to have it cracked 😉
Browni
Aspiring Hero
Fixes: 60
Re: Bluetooth query
A Google search on 'bluetooth multicast' brought this up.
It claims to be able to send audio to 2 bluetooth receivers.
gleneagles
Aspiring Legend
Fixes: 17
Re: Bluetooth query
@Browni
Thanks.
These seem to be on sale on the Amazon American site but not on the UK site, seems they did have them but are currently out of stock.
Will do a bit more researching into this
