Bluetooth help
- Bluetooth help
Bluetooth help
28-12-2013 6:56 PM
He wants to be able to pair up the iPad to his Phonak Inspiro (FM system) using a bluetooth adapter with a headphone jack.
We are unsure which one to get to RECEIVE audio from a bluetooth source.
There is 2 http://uk.cellphoneshop.net/btoreceive.html
and
http://uk.cellphoneshop.net/dongleaudio.html?cagpspn=pla&gclid=CKjj-obK07sCFWbLtAodmVgAfA
What is the difference between the 2?
Is one the SENDER to make a device that SENDS the audio to a bluetooth enabled device? The other one a RECEIVER to RECEIVE audio from another bluetooth device?
Please help. I don't want to risk ordering the wrong one.
Re: Bluetooth help
28-12-2013 7:09 PM
http://uk.cellphoneshop.net/dongleaudio.html?cagpspn=pla&gclid=CKjj-obK07sCFWbLtAodmVgAfA would be plugged into a source (PC, stereo) and would transmit audio via Bluetooth.
Re: Bluetooth help
28-12-2013 7:12 PM
EDIT: Fixed non showing image
Re: Bluetooth help
28-12-2013 7:20 PM
More instant on these forums.
@myredhotcar
Thanks for the clear up
Re: Bluetooth help
28-12-2013 7:24 PM
Just saying.
@NorthEasterner
No problem
Re: Bluetooth help
28-12-2013 7:40 PM
Quote from: myredhotcar @7up: People will always judge others on problems they've never suffered themselves.
Says the forum police who joined and decided to start moaning about copyright
I was merely pointing out that NE should try calling the company to ask because if anyone here advises wrongly and the wrong product gets ordered... well, NE won't be happy. By ringing the company and asking them directly, if it goes wrong the company are at fault and will have to put it right.
Re: Bluetooth help
28-12-2013 7:42 PM
Re: Bluetooth help
28-12-2013 9:00 PM
Re: Bluetooth help
28-12-2013 9:03 PM
The first link is obviously a receiver with a jack connector for earphones. All iPads have Bluetooth built in! The big question is "Will they connect together?"
For less than £10 it might be worth a punt.
York.
Re: Bluetooth help
28-12-2013 9:09 PM
It works on JamBox so should work no matter what
