Blue screen
juliasdream
Blue screen
I'm running XP SP2 and every time I boot it gets as faer as booting windows and a blue screen appears.
The message I get is
"Unmountable_boot_volume. Disable memory options. Tech info 0x000000ED
(0x856D3C08, 0xC0000006, 0x00000000, 0x00000000)
I tried going into the bios to change memory settings but find nothing about memory there
Its a Packard Bell AMD54 3400+ 2400Mhz wwith 1gb memory
Can anyone help?
1 REPLY
PunKrocker
Re: Blue screen
