Blocking IP Address's
ctbeckett
Is it possible that, by mistake, Plusnet is blocking access to Claranet SOHO?
Regards
Tony
8 REPLIES 8
Oldjim
Resting Legend
Fixes: 63
Re: Blocking IP Address's
ctbeckett
Thanks for prompt answer. Could you please try
https://webmail.clara.net/src/login.php
Tony
spraxyt
Resting Legend
Fixes: 75
It's OK for me too and I can reach and login to that webmail portal.
David
ctbeckett
Another prompt reply - thanks!
I have checked with Claranet and they assure me the e-mail account is OK. Claranet used 'Team Viewer' to access my machine and checked all was well at my end. They seemed to think it was but were unable to get access to their web mail via my machine.
As a last resort they suggested I query the 'accidental blocking' by Plusnet.
I have tried to access the Claranet web mail using four different machines from here!
Any suggestions welcome....
Tony
VileReynard
Fixes: 20
Restart your router - this will give you a new ip address.
spraxyt
Resting Legend
Fixes: 75
Does a tracert webmail.clara.net reach the destination (I get 80.168.46.10)? It does for me going via gateway ptw-ag02.
David
ctbeckett
Thanks - a reboot and restarting the router did the trick.
I didn't think to try re-starting the router as it is switched off  every evening when we go to bed, so is re-started very day!
This is my first time 'in the community'  - thanks for interest and help with my problem.
Tony
lordsmiff
Hi.
Just wanted to add that if you're on ADSL, you should not turn your router off at night. The equipment in your exchange monitors the active line to "train" the connection...which is to set it at the optimal speed. This process can take a couple of days sometimes.
By continually turning it off over night, the equipment in the exchange "resets" and starts again at a safe speed. You should leave it on all the time to ensure that your connection is always running full speed.
(see point 5 here: http://www.ispreview.co.uk/articles/adsltips/02.php)
Cheers,
Smiffy.
