Blocking ICMP on Plusnet Firewall
- Re: Blocking ICMP on Plusnet Firewall
05-08-2013 8:07 PM
Hi Folks,
Can the Plusnet broadband firewall be set to block ICMP? I'm getting ragged off by repeated distributed / coordinated ICMP activity against my static IP. It would be great to stop the activity before it reaches the target.
2 REPLIES 2
05-08-2013 9:32 PM
If you have a PN Technicolor router, it ignores them by default. Otherwise if some is trying to hack/crash your router, log it and report it to PN/Police
FTTP 500 regrade from Tues 28th November
16-08-2013 3:27 PM
Have you seen the possible explanation here - http://community.plus.net/forum/index.php/topic,117369
Annoying all the same
