Blocking ICMP on Plusnet Firewall
- Blocking ICMP on Plusnet Firewall
05-08-2013 8:07 PM
Hi Folks,
Can the Plusnet broadband firewall be set to block ICMP? I'm getting ragged off by repeated distributed / coordinated ICMP activity against my static IP. It would be great to stop the activity before it reaches the target.
2 REPLIES 2
Re: Blocking ICMP on Plusnet Firewall
05-08-2013 9:32 PM
If you have a PN Technicolor router, it ignores them by default. Otherwise if some is trying to hack/crash your router, log it and report it to PN/Police
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
16-08-2013 3:27 PM
Have you seen the possible explanation here - http://community.plus.net/forum/index.php/topic,117369
Annoying all the same
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.6.0 router, DrayTek WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
