Bleeping Telephone
- Re: Bleeping Telephone
Bleeping Telephone
23-10-2009 4:47 PM
Thanks for any suggestions.
23-10-2009 4:49 PM
Are you able to try turning off the wireless on your router now that you have your PC wired into it?
It could potentially be some strange wireless interference issue.
23-10-2009 4:55 PM
As I say. no real problem just occasionally annoying.
23-10-2009 5:13 PM
Not that it make a difference - have you turned of and completely disconnected the router ? - does the phone still bleep.
If so there must be a fault either with the phone , the line or the exchange.
Have you another phone to try ?.
23-10-2009 5:15 PM
It's not going to be the line or the exchange imho.
23-10-2009 5:33 PM
23-10-2009 6:43 PM
25-10-2009 10:55 AM
None of the other phone sets cause bleeps if substituted into the filter with the router.
Even get the bleeps when router is disconnected from power. As I said the bleeps come almost exactly every half hour. The offending phone set is just a bog standard BT Decor 1200 with LCD display.
So there you have it folks, WEIRD but I can live with it now I know where the cause is.
Thanks for your interest.
26-10-2009 1:02 PM
26-10-2009 2:15 PM
Graham
02-11-2009 10:40 AM
02-11-2009 11:32 AM
I think I've overcome the annoyance with much juggling of filters so 'fingers crossed'.
