Blackberry not connecting to router
- Re: Blackberry not connecting to router
04-10-2012 9:29 PM
But with this one when you scan and try to connect you get the message "this wireless router supports wi-fi protected setup. To connect using a PIN (which your Blackberry will generate), click Next". Then when you click Next you get an 8 number code. it doesn't give you the opportunity to put in the network password.
Please tell me how to connect the Blackberrys to our network. thanks
18-10-2012 6:24 AM
Has noone got a solution?
Denis
18-10-2012 5:09 PM
Home Network > Your wireless network (actual name will vary, it will be shown towards the top of the right-hand pane) > Configure (top-right) > Remove the tick from 'WPS Protected' and then apply the changes.
18-10-2012 8:17 PM
19-10-2012 12:27 PM
19-10-2012 1:33 PM
Broadcast Network Name box - tick/untick
Allow new devices - with a scroll down menu (ihave this set to automatically)
Encryption which has three choices :
Disabled
Use WEP encryption
Use WPA-PSK encryption
After that there is a box for WPA-PSK encryption key (i.e.Wireless Key supplied with router)
and a scroll down menu for WPA-PSK version : choices are WPA or WPA2 or WPA+WPA2
I'm not sure how to disable WPS from these choices.
19-10-2012 1:36 PM
20-10-2012 9:01 AM
Denis
