Bit Torrent
- Bit Torrent
Bit Torrent
05-10-2007 11:02 AM
Is anyone else having trouble using this program ?
I wonder if plusnet are blocking it?
It should work, but does not, instead just 'sits' there waiting to start downloading.
Quiz
Quiz
1 REPLY 1
Re: Bit Torrent
05-10-2007 11:19 AM
Bittorrent is given different speeds on our network dependant on which product you are on. Your product is designed as an entry level product suitable for browsing and basic internet usage.
If you have a look at this link, you'll be able to see how different products perform on different protocols.
http://usergroup.plus.net/070920_bbywcomp3.php
You may want to consider changing your product to Broadband Your Way, Option 2. For the same price, you would get 8GB usage during peak times of 0800-0000, with better P2P performance than what you are currently experiencing.
