Bios password
- Re: Bios password
Bios password
12-11-2016 8:10 PM
A quick question , i have a friends laptop needs a reinstall win7 but cant get Into Bios as its pasworded and wont let me boot from disc or USB
so which is easiest way to get into Bios ? and no its too aquard to get to battery
Re: Bios password
12-11-2016 8:23 PM
If your friend set a BIOS password then forgot it there is nothing you can do yourself. Send the computer to a service agent for the manufacturer with proof of purchase and pay for it to be reset.
A few machines have a default BIOS password set by the manufacturer (!?!) in which case you should be able to look it up. I had to do this a few months ago; the password was a four digit number that varied according to the date setting.
Re: Bios password
12-11-2016 8:31 PM
The BIOS password on my old laptop doesn't actually protect the boot menu, you can't get into the BIOS settings without the password, but you can still press the key to get to the boot menu and then choose to boot from a CD or USB.
Re: Bios password
12-11-2016 10:12 PM
Its a Old 2005 sony Vaio , it was reset at a shop but he wants £25 to do it again , he reset it to win 10 .
But friend wants win7 but shop put a password on Bios after 3 attempts it lock you out
Tried default Sony Bios pasword 1234567 , plus a few more but no luck
Re: Bios password
13-11-2016 8:34 AM
Re: Bios password
13-11-2016 9:15 AM
@rongtw seems to be plenty of options to try on this page...
Re: Bios password
13-11-2016 9:16 AM
That's extortion. It's not moral for a shop to create a BIOS password and not tell you what it is. But the charge of £25 seems very reasonable to get a working computer if you have a computer that does not work at the moment. Is there more to this than your friend is telling you?
A computer from 2005 would have been supplied running Windows XP. If it ever ran Windows 7 it must have been upgraded. You will need the licence key for the upgrade to get it back to Windows 7 even after you can access the BIOS. On the other hand if it can legitimately run Windows 10 (as an upgrade over an upgrade) then you can re-install that without having to find the Windows 7 licence key.
Re: Bios password
13-11-2016 11:17 AM - edited 13-11-2016 11:18 AM
looks like he will have to get password from shop as i dont want ot take it apart to find battery on Motherboard .
It starts in win7 , shuts down saying windows found corrupt files,tried install from win7 but cant wipe disc unless start from boot , but bios is set HD boot only
Hopefully they will give him password
Thanks for all help
Re: Bios password
13-11-2016 4:43 PM
Forget removing the battery from a laptop to clear the CMOS - that trick hasn't worked for decades. I have an old HP upstairs that I tried it with and it cleared nothing.
Desktop computers yes it usually works but laptops are ultra nickable and so the hardware vendors blocked it moons ago.
I cracked the screen putting the HP back together. Not something I'd recommend to others really.
Re: Bios password
13-11-2016 5:28 PM
There's often a jumper pin pair on the motherboard that needs shorting to clear the BIOS and load a default.
However opening up a laptop is not something to be done lightly or by the inexperienced.
Re: Bios password
13-11-2016 6:05 PM
Did you try putting 1234567 into the box on this page?
it returns some other passwords, .... but, of course,... if the shop made one up, like the managers birthday, then there is not much hope ...
Here is a video tutorial that may help.....
https://www.youtube.com/watch?v=6EeIPSWhgLc
Re: Bios password
14-11-2016 10:46 AM
Re: Bios password
14-11-2016 10:55 AM
@rongtw - If it's not to late you should ask him to ask them why they reset it in the first place, if I were paying for it I'd have had it removed, never mind reset.
Re: Bios password
14-11-2016 7:42 PM
Again on most desktops yes thats correct but experience has taught me that on laptops thats a myth because otherwise there would be no deterrent against theft.
Re: Bios password
14-11-2016 7:54 PM
Told him his engineer is off sick 😤
