Bing 3D Maps
theblisses
Bing 3D Maps
Can anyone help?  I have tried to install the 3D facility for Bing maps, but it will not work and I keep getting this message: -
alanf
Re: Bing 3D Maps
Please continue....
theblisses
Re: Bing 3D Maps
Sorry alanf,
I tried to incluge a screenshot; can you remind me how to do it?
Fixes: 53
Re: Bing 3D Maps
Assuming you've got an image file to attach, click "Additional Options and Attachments" below the text entry area where you type and use 'Browse' to locate the file. The image will be uploaded when you post - but not for previews.
David
theblisses
Re: Bing 3D Maps
Thanks spraxyt,
Fixes: 62
Re: Bing 3D Maps
which security package are you running and which version of windows and are you running as administrator or a guest
theblisses
Re: Bing 3D Maps
Oldjim, I am running Windows 7 Home premium, AVG antivirus and IE9 Beta.  And I am administrator.
Fixes: 62
Re: Bing 3D Maps
If you are running Windows 7 you aren't running as a full administrator
Try right clicking on the exe file and select Run as Administrator
theblisses
Re: Bing 3D Maps
Oldjim, I unistalled the program and then tried your suggestion; still the same result I regret to say.
