Binatone ADSL 2100 modem/router drivers
JasonH
Does any know where I can find/download the drivers for a Binatone ADSL 2100 modem/router - I'm using Vista.
Fixes: 19
Re: Binatone ADSL 2100 modem/router drivers
Routers do not require drivers (except in unusual circumstances).  You must use the Ethernet port with an Ethernet cable.
I think this old router may have had the option of connecting via a USB cable and if you have just replaced a really old computer you may have been using this.  Now you need to connect between the network (Ethernet) port on your computer and one of the network ports on the router.
Rich
I too have a Binatone ADSL2100.  This is ethernet only (no USB) and doesn't require drivers for any O/S, including Vista. It should just work
Fixes: 50
You may need to create a network connection.
Customer and Forum Moderator.
Fixes: 19
Sorry Strat, I know quite a bit about computers but I don't understand your comment.  Would you care to go in to more detail?
Fixes: 69
You could do worse than to take a look here.
Plusnet Products Team
