Billion Bipac 7300N
penfold
Fixes: 5
Billion Bipac 7300N
Hi
I bought one of these routers to replace the plusnet offing, due to the sheer number of issues I was having with it...  I am hoping for fibre soon, and noted when I bought it, you could set it up to use one of its LAN ports as a WAN port.  has anyone done this with this router, is throughput OK and how easy is it....
