Billion BiPAC 8800NL users on fibre
Marksfish
Seasoned Pro
Fixes: 4
Hi. Anyone using the Billion BiPAC 8800NL on their PN fibre connection? Just send back a Technicolor TG589vs and looking for something else. this seems to do what I want and would appreciate any feedback.
32 REPLIES 32
Marksfish
Seasoned Pro
Fixes: 4
Re: Billion BiPAC 8800NL users on fibre
Am I going to be the guinea pig then?
Mark
NoZephy
Looks that way, let us know how you get on Grin
I'll be moving to Fibre in a few months and this router was on my possible upgrade list so it'd be nice to know how it holds up from someone else on PN.
The only issue I see with it is that it doesn't seem to support vectoring?
ejs
Aspiring Hero
Fixes: 25
I gather it supports vectoring.
Gus
Can only say its very good on ADSL for long lines, since getting it my connection simply does not drop at all unless PN or BT are doing work
FTTP 500 regrade from Tues 28th November
Marksfish
Seasoned Pro
Fixes: 4
Ordered today from eBuyer. £62.99 with free delivery.
Mark
NoZephy
So it will support vectoring once Billion see vectoring implemented.
I'm definitely grabbing one of these! Cheesy
Marksfish
Seasoned Pro
Fixes: 4
So it arrived today. I saved myself £6 in next day delivery charges too  Cheesy
So, out of the box:
It wasn't as easy to get set up as I had hoped. I followed instructions from the Billion forums and I could get a connection and sync, but no connection to the internet. I tried several times, then tried the easy set up. The easy set up failed several times, so I went back to manual again. The second attempt at manual set up showed a connection success.
Sync is showing as 48 down and 15 up, so happy with that  :).
And this is the manual set up page. Time to sit back, relax and try to work out port forwarding now!!
Mark
VileReynard
Fixes: 20
What does "vectoring" mean? Note that a vector is a noun, not a verb.
NoZephy
Thanks for all the screenshots and pictures Smiley
How is it so far? aside from the setup, any problems in terms of stability etc?
Razorback
@ Marksfish    Have you used the router to replace the openreach modem as well?
nanotm
I have the 7800dxl router and I found it much simpler to just enable upnp than use port forwarding, the up side being no limitation to the number of machines that can have forwarded ports
Marksfish
Seasoned Pro
Fixes: 4
Quote from: NoZephy
It's been rock solid since I put it in, no wireless dropouts and an average 38MB download through the wireless on my laptop. Happy with it so far, will test wireless range over the weekend.
Quote from: Razorback
Yes, the OR modem has been consigned to a box  Smiley
Quote from: nanotm
My webcam didn't need configuring at all. I just added the no-ip information and away it went. On Technicolr router and Sky previously, I had to faff around, this was much quicker and easier Smiley
Mark
Oldjim
Resting Legend
Fixes: 63
Does it give you noise margin etc.
Marksfish
Seasoned Pro
Fixes: 4
Yes, there is a page full of figures and stuff. I can't pretend to understand what they all mean, but a screeshot shows what you are looking for (I think)
There is also what appears to be an option in the settinggs to set your own snr level too.
For a basic user like myself, there is plenty to play with (and hopefully not break)
Mark
