Billion 8800NL WPS Setup
adagio
I have pensioned off my 16 year old HP Deskjet in favour of a Brother HL-L2340D. Naively thought it would be a trivial matter to connect it to the network using WPS. After much head scratching and total failure, manual reads like gobbledygook and not a glimmer from the WPS light, I used a USB cable for setup - work of a moment.
Configuration screen shown - anyone know what the settings should be?
2 REPLIES 2
Strat
Fixes: 565
Re: Billion 8800NL WPS Setup
Looks ok as you've set it up manually apart from disabling WPS which you now don't need.
adagio
But with those settings it did not work.
