Billion 8800NL WPS Setup
- Billion 8800NL WPS Setup
14-10-2016 10:24 AM
I have pensioned off my 16 year old HP Deskjet in favour of a Brother HL-L2340D. Naively thought it would be a trivial matter to connect it to the network using WPS. After much head scratching and total failure, manual reads like gobbledygook and not a glimmer from the WPS light, I used a USB cable for setup - work of a moment.
Configuration screen shown - anyone know what the settings should be?
Re: Billion 8800NL WPS Setup
14-10-2016 1:20 PM
Looks ok as you've set it up manually apart from disabling WPS which you now don't need.
15-10-2016 1:13 PM
But with those settings it did not work.
