Big boot-up problems
albert
My daughter's, pc has big problems (it's an Evesham, who have stopped trading). It won't boot up. When you first switch on it says something about 'ethernet cable missing'. It gets a certain distance, such as 'checking DMI pool' but then says 'failed to boot' and asks for the 'recovery' CD. But when you put in the recovery CD it doesn't seem able to read it. In the BIOS it doesn't seem to be able to detect the HDD. It is also making some clunking noises!
All this has happened once before (some months ago). On that occasion we put the 'recovery' CD in and Windows reinstalled.
It's possible that we might find that the CD drive suddenly works but my daughter is very worried about losing all her files (which, needless to say, she hasn't backed up).  Cry
What would you advise?
a) if we manage to reinstall Windows, will her files be accessible so that we can at least back them up or will they have been 'lost'?
b) if we pull out the HDD is it possible to recover files (and where would you go to do that - is it expensive??)
c) should we buy a new pc?
I'd be grateful for any advice.
Thanks,
"Albert"
pierre_pierre
Re: Big boot-up problems
It depends if the problem is with the HDD, dont like the sound of the Clunking,  You can get a cheap caddy that takes the drive and connects to another PC via usb.
Dont scrap any computer with the HDD in it
If you have a friendly PC chappie he should be able to retrieve your data for you.  Sounds like a HD problem.  Fortunately they are expensive to replace but as Pierre said, be careful when getting rid of the old one.
VileReynard
All Star
Fixes: 11
Open up the PC and check that the HD spins up when you apply power.
Check for any loose connections.
axisofevil also meant to say "be careful because there is a risk of electrocution if you power up the PC with the cover off"
I had a couple of problem hard drives and managed to recover data ok.
As mentioned earlier you can connect your hard drive to another computer.  I used one of these these
I was able to browse the drive and recover what I needed.
You can get an EASY IDE at Maplins
I hope this helps
Quote from: artmo
I am sure that artmo's meant inexpensive  Wink
yes, I did mean inexpensive - started on the Merlot early  Grin Grin
albert
thanks, everyone. It sounds as if there is hope!
albert
PS
I've found a friend who seems to know how to look at the data on a HDD if I give it to him.
Fraid I'm not technical.
a) what is involved in removing a HDD?
b) how expensive would a new one be?
Ta!
Depending on what you want a new HD will be from around £32 and up.  Have a look at: http://www.misco.co.uk/applications/category/category_tlc.asp?CatId=2266
VileReynard
All Star
Fixes: 11
Quote from: Santiago
No I didn't  Smiley
So long as you don't poke your fingers inside the power supply, you will be safe!
However, do take anti-static precautions (small voltages can easily destroy your chips).
albert
The current HDD is a Western Digital WD 1600 160 GB 7,200 rpm
Will any HDD do or does it have to have the same specs?
the important part is wether, or not, it's ide.  other than that, practically any drive will do.  maxtor, fujitsu, seagate, they're all good.  dependent upon the bios, you could have a bigger drive.
I've always heard Maxtor or Seagate are the best but I know a lot of people who don't like Western.
albert
thanks, everyone, for all the advice... very helpful.
I've now removed the HDD and I'll get a friend to try connecting it to his PC.
In the meantime I'll get a replacement and hope that I can get Windows reinstalled. (Shouldn't be too difficult, just time-consuming).
This forum is great for non-techno types like me  Cool
