Best way to change router so DLM doesn't knock sync rate down?
markuswelby
Re: Best way to change router so DLM doesn't knock sync rate down?
@VileReynard BT do work at night where I live Smiley as well as Virgin Media do, where I live. I've seen them with tents up and bright lighting too.
Thanks for info on the router change. I know exactly what you are saying with the  suitable incantation Smiley hahahaha
Did any of your neighbours suffer this issue at the same time?
Ubuntu-MATE 18.04.3 LTS (Bionic Beaver) 64-bit
markuswelby
Anyway, I am seriously thinking of getting another new line installed and getting Plusnet fibre installed.
markuswelby
@VileReynard wrote:
You might be interested in some long-term speed results October 2018 - September 2019 and counting.
They indicate two portions where speed fell from 70Mb/sec to 30Mb/sec literally overnight.
ok, Your graph is fascinating. It's intrigued me. I wonder if there was some kind of interference for those times?
How far is your BT street cabinet away?
Could they have been upgrading your local cabinet? Putting you on a limited supply? Either temporary equipment or connected you to a cabinet further away for a short period?
VileReynard
Fixes: 20
Each interval was for about 6 weeks and as far as I know the reason remains unknown.
