Best of both worlds
Best of both worlds
My new PC has Vista, my old one had XP. the reasons for replacing the PC were never anything to do with old one's main hard drive (it eventually had two more fitted)
Can I take the old HDD (CSmiley complete with XP, and fit it into the new PC and dual boot it? and then transfer files etc. between them?
MikeWhitehead
Re: Best of both worlds
It would involve modifying the Vista boot manager. If you google "Dual boot XP and Vista" you'll find some examples of dual booting between the two.
Also, if the new PC has a motherboard which has a different IDE controller than the previous motherboard, then the drive won't be able to be read in some cases, in which case you would need to format the old XP hard drive.
Thanks Mike, the new PC has an ATA controller type HDD, the old one an ATAPI type.
Ooop's I should have said: IDE not ATAPI
