Best Non Plusnet Router for 2018
Cullen
Hi
I've been using Plusnet for a few years now and have unlimited fibre package. I've been using a Netgear D6400 but think its due for an upgrade. It runs with a speed of 1300mbs with 4 lan ports. Ideally, I'd like an upgrade in both. Thanks for any advice/recommendations.
1 REPLY 1
VileReynard
Fixes: 20
Re: Best Non Plusnet Router for 2018
I've been using a basic Fibre BT modem (available on ebay) with a Netgear WNR1000v3 router since 2012.
The LAN ports are only 100Mbs but I get 70/17 Mbs but its still going strong.
I would stick with your current speed of "1300mbs" Thumbs_Up
