Best Modem or Modem/Router to improve VDSL speed? Other tips to increase performance?
- Best Modem or Modem/Router to improve VDSL speed? ...
21-01-2019 4:11 PM
Following on from my recent thread discussing my line speed being below PN and BT estimates and there being nothing more that Plusnet can do to help, is there a modem or modem/router that might help eek out the last bit of speed?
Is there anything else I can do or try that might help to improve line speed?
Re: Best Modem or Modem/Router to improve VDSL speed? Other tips to increase performance?
21-01-2019 4:20 PM
@vultura, I run dual Vigor 130 xDSL Modems, they're not the cheapest but I've got no complaints about them. In fact I bought them for they very same reason as you are asking.
22-01-2019 10:01 PM - edited 22-01-2019 10:01 PM
@Anonymous wrote:
I run dual Vigor 130 xDSL Modems, they're not the cheapest. In fact I bought them for they very same reason as you are asking.
They are certainly not cheap, may well consider one if my latest acquisition doesn't work out.
