Belkin N1 Vision
jonchill
Belkin N1 Vision
Currently I've got a 6 yr old Thomson broadband router and its now showing its age.
I've recently bought a NAS and want to use the gig interface on it along with the gig on my PC.
I would also like to start using N.
About the only Broadband Wireless Router I could find with Gig was the Vision.
I don't want to have separate switch and wireless devices as I'm trying to cut down on the number of sockets I need to use.
Can anyone give me they're experiences with this device good and bad?
Any info would be much appreciated.
Jon
1 REPLY
Fixes: 189
Re: Belkin N1 Vision
Not used it myself but there are some quick reviews here http://www.broadbandbuyer.co.uk/Shop/Reviews.asp?ProductID=5918
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
