Batch Image Processing
Fixes: 133
Hope this is the correct forum for this question...
I used to use BIMP Lite 1.62 but, for some reason, it no longer runs. A re-install hasn't solved the issue.
Does anyone know of ant other 'free' software that can change batches of PNG, BMP, etc. to JPG files? The reason for the 'free' is that I only need it occasionally for the odd batch of 5 or 6 files at a time.
Forum Moderator and Customer
Cliff_Jordan
Re: Batch Image Processing
IrfanView can do this ...but as I've never used this facility I can't vouch for it.
Cliff
Fixes: 133
Thanks for that.
Have DL'ed it. A quick check and it appears to do what I want and, possibly, better than BIMP Lite Smiley
I must admit I use Irfanview to read comics, and have used the batch resize a few times. I've not converted, but if it's anything like the batch resize process, it's superb.
StickyMick
Irfanview is my choice for image resizing. Gives pretty good results with very little loss of quality.
Fixes: 133
I seem to be having a problem with IrfanView in that after every batch process the Batch Conversion window closes and next time I have to reset the directory folder.
I have read the help file and looked in Options but can't find a way of keeping it open.
Also, is there a way of selecting several files from different folders but having the converted files go into the respective original folders? Currently I just deal with one folder at a time.
mrmarkus1981
I just use XP Image Resizer, its in the powertools section.
http://www.microsoft.com/windowsxp/Downloads/powertoys/Xppowertoys.mspx
If you have Vista, who knows!
barky
XnView will do it for you
