Batch Image Processing
- Re: Batch Image Processing
28-05-2009 11:27 PM
I used to use BIMP Lite 1.62 but, for some reason, it no longer runs. A re-install hasn't solved the issue.
Does anyone know of ant other 'free' software that can change batches of PNG, BMP, etc. to JPG files? The reason for the 'free' is that I only need it occasionally for the odd batch of 5 or 6 files at a time.
Forum Moderator and Customer
29-05-2009 8:24 AM
Cliff
29-05-2009 9:47 AM
Have DL'ed it. A quick check and it appears to do what I want and, possibly, better than BIMP Lite
29-05-2009 11:22 AM
29-05-2009 12:22 PM
30-05-2009 10:26 AM
I have read the help file and looked in Options but can't find a way of keeping it open.
Also, is there a way of selecting several files from different folders but having the converted files go into the respective original folders? Currently I just deal with one folder at a time.
22-06-2009 3:41 PM
http://www.microsoft.com/windowsxp/Downloads/powertoys/Xppowertoys.mspx
If you have Vista, who knows!
22-06-2009 5:03 PM
