Bargain basement Samsung dual band wireless N gigabit router?
- Re: Bargain basement Samsung dual band wireless N ...
14-11-2014 2:31 PM
http://www.amazon.co.uk/Samsung-CY-SWR1100-XU-Wireless-Router/dp/B004TB512S/ref=sr_1_1?ie=UTF8&qid=1...
I don't expect it to perform as well as an Asus RT-N56u which uses the same chipset, but couldn't resist ordering one at this price given it has 4 gigabit ports. It turned up yesterday, brand new sealed box.
Apart from the blue colour scheme, the menus remind me of older Dlink routers.
Re: Bargain basement Samsung dual band wireless N gigabit router?
14-11-2014 2:37 PM
6 new from £12.78 1 used from £34.99
Which one should I buy? ? ? ? ?
14-11-2014 3:11 PM
Forum Moderator and Customer
14-11-2014 8:46 PM
One Foot Connetcion
Oh dear.
14-11-2014 9:39 PM
15-11-2014 12:33 PM
Quote from: shutter can`t figure out how to connect one foot to it ...
Generally you place the device on the floor infront of you, raise one foot behind you, swing it forward toward the device, and then once complete you have connected one foot to the device...
15-11-2014 12:42 PM
15-11-2014 12:57 PM
15-11-2014 2:15 PM
22-11-2014 6:40 PM
Some sample screen captures of the Samsung/Dlink firmware.
There is a USB2 port on the Samsung router, but it cannot be used for printer or file sharing.
(The Padavan custom firmware for the Asus RT-N56u/N65u/Belkin N750DB/Samsung SWR-1100 enables printer and file sharing on the USB port)
23-11-2014 1:25 AM
Quote from: zZz Apart from the blue colour scheme, the menus remind me of older Dlink routers.
Nowt wrong with DLink from my previous experience of them. Much better than Belkin!!!!!
30-11-2014 9:18 AM
USB file and printer sharing is available.
There isn't a wireless repeater mode, but there is a 'AP & AP Client' mode which is as close as it gets.
Some sample screen captures attached.
