Banner Ad blocker
- Re: Banner Ad blocker
Banner Ad blocker
10-03-2009 1:23 AM
Is anyone using any banner ad blocking software they can recommend? Win XP & IE6
5 REPLIES 5
10-03-2009 7:08 AM
10-03-2009 7:14 AM
use Firefox, then it easy with the AddBlock add on
10-03-2009 1:58 PM
Quote from: paulh http://www.mvps.org/winhelp2002/hosts.htm
Seconded.
10-03-2009 2:02 PM
I like the hosts file block approach and it works very well. The only down side to it is that it blocks things like tradedoubler which I get grief for from SWMBO when links she clicks don't work.
It's a shame that no one has ported http://adzapper.sourceforge.net/ to windows which I use with Squid to block ads and works really well.
11-03-2009 8:43 PM
Thanks all, especially paulh who suggested the hosts route, I hadn't considered that.
Now, with just two entries in hosts, the proliferation of banners on ebay has gone and it has made pages load a lot quicker.
For anyone else intersted the two entries I've made are......
127.0.0.1 ad.uk.doubleclick.net
127.0.0.1 srx.uk.ebayrtm.com
... and (in XP at any rate) you will find the hosts file at c:\windows\system32\etc
