Banking app
ApDan
Banking app
For two days I've been unable to access my First Direct banking app. They say they know nothing about the problem but I have read online that it is a problem with BT/Plusnet servers. When I try to login I get a message saying login failed, check internet connection. There is no problem with the connection for anything else. There was a suggestion to switch off router and try again, I did this without success.
5 REPLIES 5
Fixes: 411
Re: Banking app
If you're switching off to try to pick up a different IP address you need to leave it off for over an hour and then keep your fingers crossed as the addresses can be quite sticky.
adrianscotter
Re: Banking app
Or for £5, you can have a fixed IP address from PlusNet that's UK registered.  I had to do that in the end to use SystmOnline...
Live long and prosper!
VileReynard
Fixes: 20
Re: Banking app
Are these £5 addresses the same thing as a dynamic address that never changes?
idonno
Champion
Fixes: 6
Re: Banking app
I paid £5 for a static address when I first joined Plusnet few years back. Been the same IP address ever since.
Dynamic addresses can and do change.That's why they are called Dynamic Grin
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
VileReynard
Fixes: 20
Re: Banking app
Never mind.
