Bad vibes!
chuffchuff
Bad vibes!
Any suggestions please as to how to stop my base unit vibrating?
It is on a (laminate) floor and sometimes it vibrates really badly.
I've looked at propriety brands of vibrations mats but I really want something relatively
inexpensive and effective.
Thanks.
13 REPLIES 13
HairyMcbiker
All Star
Fixes: 21
Re: Bad vibes!
I use a piece of 1" thick foam put underneath the unit. Stops most of the noise.
The denser the better as long as it doesn't compress as much.
TORPC
Re: Bad vibes!
Is this from new or recently started happening
In either case (no pun intended)
Check the fans are not on their way out 7 are firmly fixed in place, & make sure the HDD(s) are srewed down tight, If they are all ok then as HMcB suggests should work fine
Re: Bad vibes!
I would fix the cause of the vibration, rather than trying to suppress the noise from the case.
For example, if the cause of the vibration is a fan, then try using rubber fan mounts as a set of four will only cost you £1 to £2  Wink
HairyMcbiker
All Star
Fixes: 21
Re: Bad vibes!
With mine it was a combo of the psu fan, cooling cpu fan and a hdd that was ratting about in use (just a noisy hdd rather than loose) the foam stopped the noise from being broadcast downstairs.
nanotm
Re: Bad vibes!
sounds like the fans will be causing it, grab a set of anti vibe feet for the case (rubber stick on things) if you cant identify which fan is causing the problem (sometimes the cases are just not heavy enough to compensate for the movement of the fan at full speed) again there only a few quid for a pack of 4
CX
Re: Bad vibes!
In my experience heavy vibration that can be felt outside of the case (i.e. transferred to flooring) is almost always the hard drive.
This product is the best solution to that (unless you fancy a DIY method):
http://www.amazon.co.uk/Sharkoon-Hdd-Vibe-Fixer-Enclosure-Decoupling-Drives/dp/B000FLR8PE/
Don't be tempted by the things with the rubber screws such as the one by Scythe - they are inadequate for a typical 2-3 platter 7200RPM drive. The Sharkoon HDD Vibe Fixer is equivalent to the NoVibes III, and it does work very well.
Fans tend to excite side panels, slot covers etc on the case itself, but lack the mass to usually cause problems further away (unless the case is one of those flimsy finger-cutting "£12 including a 500W PSU" types).
picbits
Re: Bad vibes!
Get some pipe foam lagging, slice it in half lengthways then put under the base of the PC.
Re: Bad vibes!
Another cheap trick to try on fans that cause case resonance, is to install a variable speed fan controller, and then slightly reduce the fan speed to a frequency that no longer rattles the PC case.
The Zalman FANMATE 2 Variable Fan Speed Controller works well and only costs a couple of quid.
rongtw
Fixes: 12
Re: Bad vibes!
TBH fans are liable to build up of Fluff or Dust causing them to be  out of balance, try to clean or blow compressed air to clear off first .
Its free  Wink
out of balance fans  make noise
w23
Fixes: 4
Re: Bad vibes!
Quote from: rongtw
Yes, first thing to check is whether fans are dirty, if so clean them.  If vibration persists then it may be Hard Discs or fans that were out of balance from new..
I'd suggest cleaning fans with a cotton-bud rather than compressed air but @rongtw gets my vote for 'best thing to try first'
Call me 'w23'
7up
Fixes: 17
Re: Bad vibes!
Look guys come on... there is a really easy way of doing this without hunting round the house for various soft materials etc and it's completely free  Cool
Just follow the 7up method: Take out all the components from the PC case. Wire them up outside the PC case on your desk / floor / other non conductive material. Turn on and use as normal while disposing of the metal case that was annoying you for so long. Job done.. the 7up way  Cheesy
VileReynard
Fixes: 20
Re: Bad vibes!
Tighten your nuts.
TORPC
Re: Bad vibes!
Quote from: 77
Quote from: rongtw
Not a good idea if you have children or animals especially wandering cats or sniffing dogs Grin
