Bad vibes!
- Re: Bad vibes!
Bad vibes!
21-03-2014 12:03 PM
It is on a (laminate) floor and sometimes it vibrates really badly.
I've looked at propriety brands of vibrations mats but I really want something relatively
inexpensive and effective.
Thanks.
Re: Bad vibes!
21-03-2014 12:07 PM
The denser the better as long as it doesn't compress as much.
Re: Bad vibes!
21-03-2014 12:33 PM
In either case (no pun intended)
Check the fans are not on their way out 7 are firmly fixed in place, & make sure the HDD(s) are srewed down tight, If they are all ok then as HMcB suggests should work fine
Re: Bad vibes!
21-03-2014 12:55 PM
For example, if the cause of the vibration is a fan, then try using rubber fan mounts as a set of four will only cost you £1 to £2
Re: Bad vibes!
21-03-2014 2:02 PM
Re: Bad vibes!
21-03-2014 2:46 PM
Re: Bad vibes!
21-03-2014 3:48 PM
This product is the best solution to that (unless you fancy a DIY method):
http://www.amazon.co.uk/Sharkoon-Hdd-Vibe-Fixer-Enclosure-Decoupling-Drives/dp/B000FLR8PE/
Don't be tempted by the things with the rubber screws such as the one by Scythe - they are inadequate for a typical 2-3 platter 7200RPM drive. The Sharkoon HDD Vibe Fixer is equivalent to the NoVibes III, and it does work very well.
Fans tend to excite side panels, slot covers etc on the case itself, but lack the mass to usually cause problems further away (unless the case is one of those flimsy finger-cutting "£12 including a 500W PSU" types).
Re: Bad vibes!
21-03-2014 6:31 PM
Re: Bad vibes!
21-03-2014 10:16 PM
The Zalman FANMATE 2 Variable Fan Speed Controller works well and only costs a couple of quid.
Re: Bad vibes!
21-03-2014 10:21 PM
Its free
out of balance fans make noise
Re: Bad vibes!
22-03-2014 12:18 AM
Quote from: rongtw TBH fans are liable to build up of Fluff or Dust causing them to be out of balance, try to clean or blow compressed air to clear off first .
Yes, first thing to check is whether fans are dirty, if so clean them. If vibration persists then it may be Hard Discs or fans that were out of balance from new..
I'd suggest cleaning fans with a cotton-bud rather than compressed air but @rongtw gets my vote for 'best thing to try first'
Re: Bad vibes!
22-03-2014 2:27 AM
Just follow the 7up method: Take out all the components from the PC case. Wire them up outside the PC case on your desk / floor / other non conductive material. Turn on and use as normal while disposing of the metal case that was annoying you for so long. Job done.. the 7up way
Re: Bad vibes!
22-03-2014 10:50 PM
Re: Bad vibes!
23-03-2014 2:12 AM
Quote from: 77
Not a good idea if you have children or animals especially wandering cats or sniffing dogs
