Bad dog!
FIXED- Subscribe to RSS Feed
- Re: Bad dog!
31-03-2017 10:30 PM
Had a rather strange restart of my router earlier which I traced back to this
20:21:38, 31 Mar. | ( 32.820000) System up, firmware version: 4.7.5.1.83.8.226 |
20:21:22, 31 Mar. | ( 16.770000) System start |
20:21:22, 31 Mar. | ( 16.760000) Boot reason: watchdog reset |
12:26:04, 29 Mar. | ( 31.930000) System up, firmware version: 4.7.5.1.83.8.226 |
12:25:48, 29 Mar. | ( 16.480000) System start |
That is the only time that reason appears in the routers lifetime as the boot section of the event log goes back to when I first joined Plusnet
16:24:45, 29 Feb. | ( 26.070000) System up, firmware version: 4.7.5.1.83.8.217 |
16:24:31, 29 Feb. | ( 12.130000) System start |
Hopefully it's just a one-off occurrence
Fixed! Go to the fix.
Re: Bad dog!
31-03-2017 11:45 PM
That'll teach you not to mess with firmware upgrades!
09-04-2017 4:39 PM
It's done it again twice in the space of a couple of days and Google searches don't throw up any reason apart from the Hub One playing silly [-Censored-]s.
Spare Hub One in place now...
00:05:23, 08 Apr. | ( 39.930000) System up, firmware version: 4.7.5.1.83.8.226 |
00:05:07, 08 Apr. | ( 24.010000) System start TR069 |
11:10:26, 07 Apr. | ( 28.330000) System up, firmware version: 4.7.5.1.83.8.217.1.1 |
11:10:11, 07 Apr. | ( 12.620000) System start |
Re: Bad dog!
09-04-2017 8:21 PM
A watchdog timer is used to detect freezes and crashes. The timer starts counting down and sends a signal to the operating system. If the operating system is alive it resets the timer before it get s to zero and the process repeats. If for some reason the operating system hangs or crashes, the timer doesn't reset and it triggers a reset of the CPU to reboot the device and get it working again.
For some reason, you're router is locking up or crashing and not resetting the timer before it counts down to zero and reboots the router.
Potential things to look at are, is the router getting too hot? Are the ventilation slots blocked up? Other possibility is you've just got a bad router.
Re: Bad dog!
13-04-2017 8:04 PM
The spare one didn't show any errors so the original must have been goosed.
Now running this bad boy
Re: Bad dog!
13-04-2017 8:17 PM
Watch dogs are a bane.
I've been trying to write a script that allows my PC to suspend to RAM after a certain period of no keyboard input, and have a ACPI timer wake it up at 7:15am. Quite difficult.
Re: Bad dog!
13-04-2017 8:51 PM
