Bad SDP - what does it mean??
Sheppy
Managed to make 2 calls isng the X-Lite software so far, each call worked BUT the next few times it didn't with "Call failed: Bad SDP" what does the mean and how can I fix it?Huh
1 REPLY 1
RichSmol
Re: Bad SDP - what does it mean??
We've had  a few speradic reports on really random issues that we can only put down to X-Lite v3 which seems to be full of small bugs. Try using v2 and see if you can replicate these issues. It seems to of worked for most other random issues we've been seeing.
You can download the v2 X-Lite from the link below:
http://www.voipuser.org/forum_topic_6405.html
