Backups and Data Analysis
VileReynard
Fixes: 20
Re: Backups and Data Analysis
Can't you just output the results of the search to a file which could then be processed by some kind of script to carry out the desired actions?
RobPN
Fixes: 13
@TeeGee wrote:
Search Update:
Search Gives a mass of options in Windows 10 listing everything with a view of the image. You can also click into the viewer to see full frame and move to the next one. Sadly, in either view it does not seem possible to delete via Search!
Thought I was nearly there.....
@TeeGee
I can't speak for Win10, but both Win7 native search and FileLocator Lite allow you to delete (and a few other things) from within the search results.
Have you tried right-clicking on the files you wish to delete?
TeeGee
Seasoned Pro
@RobPN wrote:
@TeeGee wrote:
Search Update:
@TeeGee
I think I have cracked it! FileLocatoreLite. W7. Log in as Administrator.
List files *.jpg in drive or folder
Select 20 or so files
Right click Open or Preview.
Files can now be deleted from the view screen!
Thanks to all and off to pot on tomatoes now.  This and backup is really a job for dark nights!
VileReynard
Fixes: 20
Got any JPEG files? 😀
TeeGee
Seasoned Pro
Yes - TWO.......😇
