Backup
gleneagles
Aspiring Legend
Fixes: 17
Backup
If using a dual boot system, linux and windows, is there any way linux can make a backup of the whole system ? ie linux and windows.
Having been caught out by making a back up of the windows partition only to discover a failing hard drive could only be read by linux . I do not want to be caught out again.
We are born into history and history is born into us.
3 REPLIES 3
HairyMcbiker
All Star
Fixes: 21
Re: Backup
Do you want a complete copy of the hdd if so look at Clonezilla
If only the data, mount the win drive while in Linux and copy the data somewhere else
VileReynard
Fixes: 20
Re: Backup
I periodically boot from a Linux USB and copy all files Partion-1 -> Partition-1 on backup device, Partion-2 -> Partition-2 on backup device etc. This way, I get a file level backup.
It is essential that you run your backup from a separate OS.
The massive initial copy will take ages, so you need to use rsync for future backups to get some speed!
Personally, I format the external disk with LVM, for flexibility.
ReedRichards
Seasoned Pro
Fixes: 25
Re: Backup
I use Acronis True image for backups.  That should allow you to back-up the entire hard drive.  You can do this from a boot disk but that's not necessary if you are running it under Windows.
