Backup on D Partition - can I delete?
Using the Vista backup facility last month I somehow managed to backup to my D partition. On my laptop the D is empty and not for recovery (I have the full disc for this).
Is it OK to delete the backup as I am going to do the thing properly this time and put it on DVD? I don't want to delete and then end up with error messages that I can't solve.
Re: Backup on D Partition - can I delete?
if its empty then you can delete it ok
Thank you - will do.
