Backing up to an external hard drive
juliasdream
I persuaded a friend to start using an external hard drive to back up files and store photos and music
He's a bit computer illiterate and found my way of dragging and dropping files a bit confusing
I said I'd try and find if theres any programs out there(preferably free) which could make the task easier for him
Can anyone help?
6 REPLIES 6
198kHz
Fixes: 41
Re: Backing up to an external hard drive
Does his OS have 'Briefcase'? Works well for me to keep things in sync.
One thing I found, though - doesn't seem to work using 'My Documents', but 'Documents and Settings\Name\My Documents' does.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Oldjim
Resting Legend
Fixes: 63
juliasdream
Quote from: Oldjim
Use SyncToy
Thanks for that
I notice that there are 2 versions , x64 and x86
He has 32bit vista. I'm not really clear on which version to choose
What would you suggest?
ckcomputing
juliasdream,
Use this one for 32bit OS (SyncToySetupPackage_v21_x86.exe)
Kind regards,
Professionals are predictable - it's the amateurs that are dangerous!
ckcomputing
juliasdream,
This is the link :-
http://www.microsoft.com/downloads/details.aspx?familyid=c26efa36-98e0-4ee9-a7c5-98d0592d8c52&displa...
Kind regards,
Cheesy
HPsauce
Quote from: juliasdream
He has 32bit vista.
I'd actually suggest using the standard backup utility built into Vista. It's perfectly OK and works well.  Wink
For full gory details read this: http://technet.microsoft.com/en-us/magazine/2007.09.backup.aspx
